Latest from Finishing
ABB Robotics
Norton | Saint-Gobain
ATI Industrial Automation
Rosler North America
TSA plunge finishers eliminate impingement during processing, and are well suited for finishing gears, automotive wheels, engine and transmission parts, and profiling rollers.
“Plunge” Finishing for Cleaning, Polishing
Aug. 13, 2012
40x the grinding power of rotary vibrators Variable speed control, vertical oscillation, and eccentric orbital movement
Rosler, the developer of surface-finishing systems, announced a new line of plunge finishers — the TSA series. These powerful plunge finishers provide an excellent high-gloss polish even as they debur, grind, and radius complex parts. They are ideally suited for components with many contours or multifaceted geometries, as well as parts made from hard alloys that are difficult to machine.
With 40x the grinding power of rotary vibrators, the TSA plunge finishers eliminate impingement during processing, and are well suited for finishing gears, automotive wheels, engine and transmission parts, and profiling rollers. With variable speed control, vertical oscillation, and eccentric orbital movement, the TSA plunge finisher is very versatile.
Durable plunge finishers can be configured for robotic interface for easy loading and unloading.
They are designed with heavy-duty construction and industrial grade motors. All TSA machines include a work bowl lined with highly wear-resistant polyurethane for years of durable service.
Each TSA plunge finisher is supplied with a user-friendly PLC-based control panel for programming of all essential operations. Other convenient features include a media unload plug for quick and easy media changes as well as dosing equipment for accurately managing water and compounds.
TSA plunge finishers can be easily integrated into your cell manufacturing concepts or designed with multi-stage processes
Visit www.rosler.us
