Latest from Materials
Branimir Ritonja | Dreamstime
Automotive cast parts.
Seesea | Dreamstime
Fire photo
Jacek Sopotnicki | Dreamstime
With deoxidized base iron, carbon levels can be increased to 3.30% C and alloying can be completely or nearly eliminated at the same time.
Diecasting mold component.
Grading Tool Steels
Jan. 23, 2024
Tool steel metallurgy uses letters to designate the composition and/or function of a variety of materials developed for hardness and wear-resistance. Can you crack the spell?
Tool steels are typically cast as ingots, not parts – but the metallurgy is important to innumerable products used by metalcasters and all manufacturers. These carbon and alloy steels are characterized by the metallurgy and/or treatment processes defined in order to achieve varying qualities of wear resistance, heat resistance, and hardness in the final use.
Applications include cutting tools, forming tools, handling tools, and particularly mold materials for casting, diecasting, forging, injection molding, stamping, etc.
Tool steels are classified by a series of lettered designations and organized according to their alloy composition and/or treatment. Check your grades:
