When people hear of “green” technology they assume it refers to alternative energy sources, like solar, wind, water, and geothermal. Clean, electric energy is overlooked, including electricity used to melt aluminum. Following here is an examination of various electric melting and holding furnaces designs, and their efficiencies compared to fossil fuel fired units.
Electric reverb melting — For 40 years the electric radiant-roof reverb furnace has been many metalcasters’ first choice for low-cost production of clean, high-quality aluminum.  A reliable, solid-state power control unit controls the electric version of the radiant-roof furnace and the temperature controller is a 1.4% accuracy, single-loop microprocessor with full proportioning features. This allows very close
temperature control, avoiding the widely fluctuating “on-off” system. The control panel is completely automatic and comes with a set of high-low alarm functions to ensure proper casting temperatures. If the furnace should overheat to a preset alarm level the panel will shut down. Also, “alarm-type” control thermocouples in these furnaces will sound an alarm if a thermocouple protection tube should leak.
1.  Electric furnaces are offered with holding capacities from 1,200 to 20,000 lbs. These metal capacities allow for maximum drawdown prior to recharging.
2.  The furnace is capable of “melting back down” if a metal freeze-up occurs due to extended power failure. The time frame of the re-melt depends on metal temperature and holding capacity. Keep in mind it is not a good furnace practice to allow the metal to freeze.
3.  The most common dip well sizes range from 12x12 in. up to 24x24 in.  Exposed well surface losses will run at 7400 BTUs per square feet per hour at 1,250° F metal temperature, therefore the sizing of the dip well should always follow careful consideration. Most customers prefer an "in-line" configuration with the charge well on one end and the hot metal dip-out well on the other end.
4.  Energy consumption is very low in a gas-fired furnace. For example, a 2,000-lb capacity holder at 1,250° F will use approximately 25 BTUs/lb/hr to hold, with the well covers in place. An electric, low-energy holder under the same conditions has a rate of 0.00205 kW/lb
Electric versus gas — Silicon-carbide resistance elements transfer radiant heat to the workload to melt with only 0.23-0.25 kW/lb. And, metal melt loss is less than 1% when charged evenly. That fact alone promotes a relatively short payback on this electric melter. From a standpoint of furnace efficiency, electric furnaces are about 67% efficient. Gas-fired furnaces are at best 37% efficient, unless they are fitted with heat exchangers or regenerative burners. Consider:
•  A 600-lb/hr furnace operating 20 hours per day and 340 days/year will melt 4,080,000 lb of aluminum per year.
•  A typical gas-fired furnace will achieve approximately 3% in metal melt loss.
•  3% of 4,080,000 lb is 122,400 lb of metal melt loss.
•  A typical electric furnace loses approximately 1% in metal melt loss.
•  1% of 4,080,000lb is 40,800lb of metal melt loss.
•  Compared to gas-fired melting, electric reverb melting will save over 81,600 lb/year, which at $1.20/lb equals $97,920.00 saved per year.
Depending upon your costs for electricity and natural gas, your energy costs will be $51,612.00 (using 0.055 cents per kW) for electric melting; or $33,560.00 (using $5.50/1,000 cu.ft.) for gas-fired melting, and spend an additional $17,950.00 to melt with electricity1. Add up the savings, subtract the extra costs, and the difference is still less than a year of payback.
Holding costs — If a furnace holds about 5,200lb with well covers in place (using 30-38 BTUs/lb/hr) that will average 35 BTUs/lb/hr for a gas fired melter* (182,600 BTUs/hr) during idle times to hold temperature and .005968 kW/lb/hr in the electric melter2 (31.035 kW/hr) @ 1,250°F. These numbers are built into the melting numbers since you do not melt the entire 60 minutes of an hour.
While these numbers are theoretical they represent a conservative forecast of what may be achieved with proper charging practices and cleaning procedures. Other advantages of electric reverb furnace melting include: No need to obtain a permit for the flue, and less heat in the building; quiet operation; very high quality metal; no need to transport molten metal; and less make-up air is required in the plant. In addition, emissions are reduced from 148.41lb/hr C02 to 0; 118.14lb/hr of H20 to 0; and 708.294lb/hr of NOx to 0.
There are disadvantages, too: Electric reverbs do not have very good recovery rates, so if production volumes increase the electric melter may not keep up the pace. Also, charge rates must be maintained evenly or the vessel will lose temperature, and have a hard time recovering the loss. Electric furnaces develop oxide, just as gas-fired furnaces do, and electric reverbs usually hold about nine times the melting volume.
For diecasting operations with a series of machines (all on the same level, processing a common alloy), electric launders provide some benefits with clean energy. They can hold metal at 1,250° F for less than 1 kW/ft of launder. They perform a quiet transfer of the aluminum, which promotes metal quality and reduces melt loss. You may lose up to 0.5% of metal in the dross by pouring metal into holding furnaces. Remember: the aluminum must go through three turbulent transfers if you do not use a launder: from the melter to the transfer ladle (tap out or pump); pouring into a holding furnace; and ladling into the shot sleeve. Turbulent transfers cause oxides and inclusions in the metal that affect scrap rates considerably.
