Jonathan Weiss | Dreamstime
SinterCast
Diecasting mold component.
Goodfellow high-purity molded fused-silica melting vessels are available in a range of sizes, capacities, and shapes, including square, cylindrical and rectangular. Customized sizes also are available.
Fused-Silica Melting Vessels
June 4, 2013
Molded for optimal melting characteristics One-piece construction, uniform microstructure
GOODFELLOW CORP.’s fused-silica is a popular choice of materials for melting vessels due to its thermal and chemical stability: it makes it possible for vessels to be used with a wide range of materials that may be subject to rapid temperature changes during processing.
However, some manufacturing methods may lead to inconsistent vessels, which risk a much-reduced lifetime, or even failure, during the melting process. To overcome these shortcomings, Goodfellow’s high-purity fused silica melting vessels are molded, producing optimal characteristics for demanding melting applications.
Specific features of high-purity molded fused silica melting vessels include:
•  Seamless one-piece construction of fully dense material;
•  Uniform microstructure with isotropic properties;
•  Nonporous, unreactive internal surface for easy removal of melted material;
•  High-purity fused silica to minimize the possibility of product contamination;
•  Long lifetime of the melting vessel.
Goodfellow offers high-purity molded fused-silica melting vessels in a range of sizes, capacities, and shapes, including square, cylindrical and rectangular. Customized sizes can be produced, with current maximum outer diameter of 635 mm and height of 400 mm.
Visit www.goodfellow-ceramics.com
