Norton | Saint-Gobain
Titan Tool Supply
Boxx Technologies
ATC Diversified Electronics
The SENSERT™ remote monitoring and alert system
Remote, Whole-Plant Monitoring
Aug. 2, 2022
A scalable technology makes it possible to monitor critical processes for a wide range of conditions – plus an alert system sets up easily, is affordable, and uses existing sensors, not proprietary devices.
ATC DIVERSIFIED ELECTRONICS introduced scalable technology that makes it possible to remotely monitor critical processes for a wide range of conditions. The SENSERT remote monitoring and alert system sets up easily, is affordable, and uses existing sensors – meaning there is no committing to proprietary devices.
Various sensors can be hardwired directly to the SENSERT base unit or wirelessly connected via the SENSERT remote I/O for true wireless, remote, online capability. Sensor data is monitored in real time and alerts are triggered based on customizable thresholds, easily configurable through the SENSERT mobile app or web portal.
Each channel can be configured for a high and low threshold value as well as custom alerts. Perhaps best of all, SENSERT works with any commercially available 0-20 milliamp, 4-20 milliamp, 0-5 volt or 0-10 volt sensors.
SENSERT is engineered to monitor sensors in critical processes and provide alerts to the user in numerous environments. It can monitor a range of conditions including level, temperature, pressure, flow, and current—as well as vibration, presence of voltage, and others.
SENSERT is a modular approach to whole-plant remote process measurement and monitoring. Where traditional condition-monitoring systems are often siloed and only monitor for a limited number of condition types, SENSERT measures many, using any sensors in the appropriate milliamp/volt parameters, while offering true wireless, remote, online capability.
Learn more at www.sensertio.com
