Brass Knuckle Safety Products
Brass Knuckle Read is cost-effective and lightweight bifocal eye protection that fits well and is available in five diopter strengths.
Bifocal Protective Eyewear
Aug. 28, 2023
For workers who need corrective lenses, Read is cost-effective and lightweight eye protection that fits well and is available in five diopter strengths.
BRASS KNUCKLE introduced a less bulky, more comfortable alternative to over-the-glasses protective eyewear for workers who required corrective lenses. Brass Knuckle® Read is cost-effective and lightweight bifocal eye protection that fits well and is available in five diopter strengths: 1.0, 1.5, 2.0, 2.5, and 3.0. A durable polycarbonate frame provides extra side protection and all-day comfort. And of course, the clear lenses are ANSI-rated hard-coated polycarbonate with BK-Anti-FOG.
BK-Anti-FOG lasts a full two minutes, 15 times longer than European EN 166/168, the only current documented standard in the world. It is permanently bonded to the lens, will not wear off or wash off, and retains its anti-scratch, anti-static, and UV protection properties.
The number of Americans between 55 and 64 in the workplace will increase by nearly 44 percent over the next decade, and these workers will continue to read gauges and valve settings, set machinery controls, and monitor production screens on the plant floor. They will calibrate, cut, and tune. And they will take their protective eyewear off and slide on their readers to make this close work easier — unless we see the problem before the accident happens.
The revised ANSI/SEA Z87.1-2015 standard recognizes the need for protective readers that offer magnification for the wearer.
Learn more at www.brassknuckleprotection.com
