Norton | Saint-Gobain
Titan Tool Supply
Boxx Technologies
Foundrymag 1094 88596fmt0319npa00000061113 0
Replacement Blades, Parts for Blast-Cleaning Machines
March 19, 2012
Affordable, easy-to-replace EZ-Fit parts
ASTECH INC. is offering a new series of EZ Fit Solutions replacement component parts for OEM blasting-cleaning machines. Astech manufactures high-performance replacement parts for blast-cleaning operations in metalcasting and other industries, including parts for machines produced by Wheelabrator, Pangborn, BCP, Goff, and others.
EZ Fit Solutions replacement parts include blades engineered and manufactured by Astech that adapt to any existing retrofit wheel.
The Michigan company also operates a steel foundry specializing in production of castings for heat, wear, and corrosion resistance. Its products are cast in a variety of alloys, including manganese steel, carbon steel, low-alloy steel, stainless steel, tool steels, high-chromium white irons, and many nickel based alloys.
The EZ Fit Solutions replacement parts are described as higher performing and more affordably priced than the current OEM retrofit wheel offerings, which also can be difficult to replace. EZ Fit Solutions include blades engineered and manufactured by Astech that quickly adapt to any existing retrofit wheel.
“Our new EZ Fit Solutions are really plug-and-play with parts that are simple to install, last longer, and cost less. Our expertise as a foundry puts us in an ideal testing environment for developing more-efficient foundry tools. We are pleased to bring the very best in blast wheel replacement parts to especially reduce installation and part cost,” stated Alan Bukach, Astech Inc. president.
Visit www.astechblast.net.
