Martech Services Co.
ATI Industrial Automation
Np Ati Rce710 Material Removal Tool 800 600fb3e648e6b
All-in-One End Effector Kits for Cobots
Jan. 26, 2021
Options for automatic tool changing, force sensing, and material removal increase flexibility of collaborative robotic automation for assembly, machine tending, part inspection, surface prep, and more.
The ATI INDUSTRIAL AUTOMATION CRX-Ready End-Effector Kits provide FANUC CRX cobot users a simple and effective way to increase the flexibility of collaborative robotic automation. These all-in-one packages include robust options for automatic tool changing, force sensing, material removal, and enable tasks such as assembly, machine tending, part inspection, surface preparation, and others to be implemented and executed easily.
The kits include everything needed to get FANUC CRX cobot applications up and running. In addition to the end-effector, the kit features all the hardware and software required for system connection. Within the teach pendant are simple controls to program the equipment and simplify complex tasks, and through just a few programming adjustments the ATI end-effectors can be easily repurposed and adapted for future applications.
The CRX-Ready Kits are currently available for the following end-effectors:
•    The QC-7 Robotic Tool Changer, ATI’s newest standard robotic tool changing and storage solution. This lightweight yet durable tool changer offers a variety of configuration options with ATI’s Pass-Through Utility Modules and Tool Stand systems.
•    ATI’s MC-10 Manual Tool Changer, which makes changing tools by hand affordable and effective. & bull; The MC-10 features a patented locking mechanism and an ergonomic design that includes tactile click as well as a visual indicator of Lock/Unlock status.
•    The AOV-10 Axially-Compliant Orbital Sander, the ideal robotic solution for surface preparation and finishing. With built-in compliance, the AOV-10 is well-suited for many different robotic application types—even those that require a light touch.
•    The Compliant Deburring Blade (CDB), a motorless deburring tool for operations such as edge deburring, chamfering, countersinking, scraping and deflashing on virtually any material. As the cutting media removes material, the compliance allows for consistent results despite variation in part size, part positioning, or robot location.
•    ATI’s RCV-250 Radially Compliant Deburring Tool, designed for the removal of flash and parting lines, as well as edge deburring from a variety of materials. The robust RCV-250 has integrated compliance and adjustable cutting force which simplify programming and enable a consistent finish.
•    The Axia90 Force/Torque Sensor, a high-performance, low-cost sensor that measures all components of force and torque. The Axia90 offers the highest resolution, accuracy, and stiffness available and gives your cobot responsiveness to sense and adapt to its environment. Learn more at www.ati-ia.com/CRX
