Martech Services Co.
Torque Sensor
Sept. 22, 2008
For testing conveniences
KISTLER INSTRUMENT'S torque sensor series 4503 A has two separately calibrated test ranges invaluable for simplified rotary device testing. The instrument is able to sense specimen operating ranges and additionally sense the torque peaks far above nameplate levels encountered in typical test sequences. Internal non-contact signal transmission is used for long life. The unit has a protection rating of IP40.
