Martech Services Co.
Electric Vacuum Lifters
June 25, 2007
ANVER CORPORATION's electric-powered, ergonomic vacuum lifter safely picks up ingots from the top without blocking or damaging them. The below-the-hook vacuum lifter features a foam suction cup and a vacuum gauge on the front cover, as ...
ANVER CORPORATION's electric-powered, ergonomic vacuum lifter safely picks up ingots from the top without blocking or damaging them. The below-the-hook vacuum lifter features a foam suction cup and a vacuum gauge on the front cover, as audio-visual alarms, and a check valve with a reservoir to help maintain vacuum if the power is interrupted. www.anver.com
