Martech Services Co.
Ultra-Low Water Castable Refractories
March 2, 2007
ALLIED MINERAL PRODUCTS' V-CAST 700 series castables are a line of ultra-low water castables, designed for molten iron contact areas in channel furnaces, cupolas, transfer ladles, lauders, receivers, troughs and runners, and other molten metal ...
ALLIED MINERAL PRODUCTS' V-CAST 700 series castables are a line of ultra-low water castables, designed for molten iron contact areas in channel furnaces, cupolas, transfer ladles, lauders, receivers, troughs and runners, and other molten metal applications. They require 4.5% or less water by weight for casting and some are as low as 3.5%. V-CAST 700 develops an advanced ceramic bond that is more stable, has superior creep resistance, improves bond strength, and has better corrosion resistance than clay-bonded systems. And it contains high purity additives which maximize performance in corrosive environments.
www.alliedmin.com
