Martech Services Co.
Large-Capacity Spray Washing Cabinet
Aug. 29, 2011
Chamber houses a rotating workbasket that holds up to 3,500 lb
The RTW 6060 is built from 0.25-in. reinforced plate steel. It has complete fluid reservoir insulation, and a thermostat and thermocouple to monitor and maintain reservoir fluid temperature and energy efficiency.
Viking Blast & Wash Systems is introducing the RTW 6060 Rotary Waterblaster spray cabinet, a large-capacity washer with a work envelope that is 60 in. high and 60 in. in diameter, housing a rotating workbasket that can support up to 3,500 lb. The standard RTW 6060 is provided with two 15-HP seal-less pumps rated at a capacity of 600 gallons per minute at 65 PSI. Pump horsepower upgrades are available, as are high-pressure options for additional cleaning power.
Standard features include a low-water, high-temperature fail switch that shuts off the gas burner, protecting the heater; a safety interlock to prevent pump operation with the washer door open; and a disc-style oil skimmer to remove tramp oils and fine solids from the detergent, extending the life of the cleaning solution.
The RTW6060 has a solid cabinet built of 0.25-in. reinforced plate steel. The machine also includes complete fluid reservoir insulation, and thermostat and thermocouple to monitor and maintain reservoir fluid temperature and energy efficiency.
Viking Blast and Wash Systems offers a range of batch style cabinet blasters and pass-through conveyances, including spinner hangers, roller table, pass through monorail, vibratory degreasing, tumble blast, rotary table, chainbelt, pass through washers, and replacement parts and media.
Visit www.vikingcorporation.com
