Martech Services Co.
Vertical Machining Center
Oct. 15, 2009
For large part hardmilling of 50+ HRc
MAKINO'S has upgraded its V56 vertical machining center, designed specifically for large part, high-speed hardmilling. It provides users with tighter accuracies, sustained dynamic performance, superior surface finishes, and long hours of continuous, unattended operation. The refined spindle increases stiffness and rigidity to reduce potential chatter during machining of 50+ HRc materials. Features a 1,050 x 550 mm table.
