Martech Services Co.
Stronghold Coatings
Stronghold Coatings Dichtol 1525 comparison
Modified, Water-Based Polymeric Capillary Sealer
May 7, 2018
Dichtol 1525 solvent-free formula suitable for confined spaces; approved for military applications
STRONGHOLD COATING SYSTEMS’ Dichtol 1525, a modified water-based polymeric capillary sealer for castings and composites, has been approved for military applications. Four NIIN numbers were issued, corresponding to package sizes, from pint-sized containers to five-gallon containers.
With no solvents, this formulation is recommended for confined space applications. It impregnates micropores and hairline cracks without vacuum or pressure, forming a protective barrier to gasses and liquids that is invisible when cured. Dichtol 1525 penetrates up to 0.004 in. into the coating to prevent corrosion of the metal substrate.
Pressure resistant to 8700 psi, and temperature resistant to 932°F, this product is suitable for castings, cables, composite materials, and more.
Applicable by dipping, brushing, injection, or pump sprayer, Dichtol 1525 dries in minutes and cures at ambient temperature. It will significantly increase machinability and dampen vibration, according to the developer, enhancing the utility of treated components of all types of metals.
Stronghold Coating Systems is the exclusive North American supplier of DIAMANT products for structural repair for critical applications. Dichtol was developed by DIAMANT and is manufactured by Stronghold in the U.S.
Learn more at www.Strongholdone.com.
