The E INSTRUMENTS INTL. LLC Inconel flue-gas sampling probes with a sintered filter are essential for many combustion applications, including melting furnaces that produce flue gases with high temperatures and large amounts of dust, particulates, and ash. They are effective for use in flue gases up to 2,200oF, or 1,200oC.
The probes available in lengths of 40 in./1 m or 60 in. / 1.5-m. The sintered filters are supplied with a half-shield for easy mounting to the end of a probe shaft.
Each probe includes a 100-ft./3-m sampling hose, with hose extensions available as needed.
The probes are compatible with all E Instruments portable industrial flue gas and emissions analyzers.
Learn more at www.E-Inst.com
