Martech Services Co.
Extech Instruments
Extech Instruments BR250-4
Minimally Invasive Video Inspection Camera
Sept. 24, 2018
Affordable borescope accesses opening as small as 4.5 mm, delivers clear images on a wireless display
EXTECH INSTRUMENTS launched of the BR250-4, an affordable and versatile wireless inspection borescope designed to get into openings as small as 4.5 mm while providing bright clear images on its detachable, wireless display. The new BR250-4 narrow-diameter camera introduces greater accessibility than had been available previously on general-purpose cameras.
Installation, inspection and diagnostic jobs often require access to hard-to-reach or -see areas. Professionals from industrial and manufacturing sectors to disaster restoration, to HVAC are using Extech’s wireless video inspection borescope cameras to access very tight spots with 2GB capacity to record video or snap photos. By accessing smaller openings or requiring smaller holes to be drilled for access, the BR250-4 simplifies diagnostics and inspection documentation, leaving minimal or no damage in the process.
The detachable, wireless 3.5-in. color display allows users to position the borescope as needed to access a difficult location without losing sight of the display. The monitor can be handheld and kept in direct view or affixed to any metallic surface using the included magnetic mount. Alternately, for inspection sites near hazardous or moving components, take the wireless monitor with you and inspect conditions remotely up to 32 ft (9.75 m) away.
Captured video (960x240 AVI) and images (640x480 JPEG) can be viewed on the unit’s monitor or transferred to a computer via the 2GB SD card or USB cable (both included). Additionally, video-out connectivity permits viewing on an external monitor.
For instructors, live video from the camera can also be received by the BRD10 wireless USB video receiver for transmission on live internet video streams.
The BR250-4 features the waterproof (IP67-rated) 4.5-mm-diameter BR-4CAM camera with a 63° viewing angle and bright, adjustable 4-LED lighting. The camera uses a 39-in. (1-m) “semi-rigid” flexible gooseneck cable which easily retains a fixed shape.
The new camera is backed by a one-year warranty and comes in a hard carrying case, with magnetic base stand, microSD memory card and adaptor, USB and video cables, AC adaptor, rechargeable display battery and four AA batteries.
Learn more at www.extech.com
