Martech Services Co.
Sinto Surface Treatment
Sinto America’s Surface Treatment Test Center
Drum Shot-Blasting Machines
March 12, 2019
Faster, safer, and cleaner finishing with powerful, centrifugal blast wheels
Sinto America’s SINTO SURFACE TREATMENT drum shot-blast machines allow for faster, safer, and cleaner finishing, with powerful, centrifugal blast wheels that have been demonstrated effective in thousands of applications worldwide. The hydraulic loader on the drum blast machines minimize breakage and damage to the parts, with smooth and reliable loading.
The core of these machines are a one-piece manganese drum, available in 3- to 35-cubic foot capacities. The manganese drum increases working life and has an a "zero-pinch" design. An adjustable drum-oscillation function during blasting reorients the parts to expose more surfaces to the blast stream, increasing overall part cleanliness. These systems combine to decrease cycle time over conventional steel-belt tumble blasts by as much as 50%, with no flights to replace, no chains to break, and no pins or links to wear out.
Sinto Surface Treatment is a division of Roberts Sinto Corp., a part of Sinto America Inc. It strives to be the leader in the design and manufacture for all surface-treatment, metal finishing. and shot-blasting applications, from standard to custom, simple or complex, an individual piece of equipment or a full system.
Learn more at www.sintoamerica.com.
