Martech Services Co.
Titan Tool
TVG PRO
Videoscopes for Remote Visual Inspection
Nov. 4, 2019
Series of five models with interchangeable probes that allow use of different insertion tube lengths and diameters with one video unit
TITAN TOOL SUPPLY INC. introduced a new line of industrial videoscopes featuring interchangeable video probes that allow use of different insertion tube lengths and diameters with one video unit. The five TVG-PRO Series videoscopes feature tungsten-braid cables in combinations of three lengths (1.5 m/59 in.; 2 m / 78 in.; 3 m / 118 in.) and three diameters (2.8 mm / 0.110 in.; 4 mm / 0.157 in.; and 6 mm / 0.236 in.)
The modular videoscopes have either 180-degree or full 360-degree articulation with only one video control handle using any of the easily-changed cables.
TVG-PRO Series videoscopes are designed for on-site inspections and maintenance for castings and other objects, including a wide range of equipment for aviation, locomotive, and gas and diesel engines, as well as machinery. Uses also include other manufacturing and metalworking operations, to inspect cavities, pipeline systems, and containers, as well as power generating installation.
The videoscopes feature a 50-in. LCD monitor with five levels of brightness control and high-intensity LED illumination to provide 100,000 hours of life. The field of view is 80° or 90°, and the depth of view is 10-80 mm or 15 mm to infinity, depending on the model.
A durable, protective case has a precision-cut insert for safe carrying and storage.
Learn more at www.TitanToolSupply.com.
