Illinois Metalcaster Damaged by Fire
Extensive damage in pattern-storage area of 150-year-old Westwick Foundry
May 14, 2012
According to local news reports, the Westwick Foundry in Galena, IL, was badly damaged by fire on Tuesday, May 8. The ductile iron foundry was built more than 150 years ago and the operations are arranged in several adjoining structures, only some of which were damaged.
None of the estimated 15 workers on the scene were harmed, though one fireman suffered an injury in the effort to extinguish the flames.
“There were no major injuries and we have not determined the cause,” Galena Fire Department chief Mike Simmons stated. “The state fire marshal has been called. The cause is up in the air until they (inspectors) decide.”
Simmons indicated the fire started in an area used to grind finished castings and then spread to a pattern storage area, where the damage was extensive. Galena City Administrator Mark Moran told local reporters that the fire “did not affect the entire building, so they may be able to still operate on some level.”
The fire was so substantial that crews from neighboring cities were called to help the Galena Fire Department battle the flames.
