Brass Knuckle
Brass Knuckle® Grasshopper (BKDST-1010N) combines comfort with protection against dust and dirt – and fog. An EVA foam dust filter with built-in air channels fills the gap between the glasses and the face, keeping dust out.
Comfortable Eyewear Protects Against Dust
April 25, 2023
Work goggles have a soft EVA foam dust filter with built-in air channels to seal the gap between the glasses and the face, keeping dust out – and convert easily into standard protective eyewear.
The Grasshopper eyewear series from BRASS KNUCKLE combines superior comfort features with a wall of protection against dust and dirt – and fog. A soft EVA foam dust filter with built-in air channels fills the gap between the glasses and the face, keeping dust out. These goggles now also quickly transform, as the dust gasket is removable to allow for conversion into standard protective eyewear, so they help the wearer move easily from job to job.
In addition to a clear lens, for further versatility Grasshopper is available in a smoke lens for normal outdoor conditions (18% of light passes through), while indoor/outdoor clear mirror lenses provide all-around tint for protection from the glare of bright artificial lighting and sunlight (50% of light passes through). Ideal for workers who change environments throughout the day, a mirror finish allows optical clarity indoors and reduces glare outdoors.
For extra safety, Grasshopper is fully dielectric with no metal anywhere in its construction.
Outfitted with proprietary Brass Knuckle BK-Anti-FOG coating, this is not a typical spray-on film. BK-Anti-FOG is bonded directly to the lens and tested under the most stringent anti-fog standard in the world, the European EN 166/168 standard. BK-Anti-FOG’s properties exceed the minimum set forth by that standard fifteen times over. In addition to excellent anti-fog performance, these glasses also offer abrasion, chemical, and UV resistance that meet demanding industry test requirements (ANSI Z87.1+, EN166K, EN166N, EN166UV).
The sporty design includes bend-but-don’t-break, super-flex TPR temples that adapt to any facial profile without distorting optics, while also providing hypoallergenic, non-slip comfort. The soft-foam dust filter gasket effectively keeps dust out without feeling uncomfortable to the wearer. Molded nosepieces add to the all-day wearability.
Learn more at www.brassknuckleprotection.com
