Cooling Towers
Nov. 22, 2006
MOKON s line of cooling towers complement its existing circulating liquid temperature control systems, and portable and central chillers. The all-galvanized cooling towers feature an induced-draft, cross-flow design that saves on fan and pump ...
MOKON s line of cooling towers complement its existing circulating liquid temperature control systems, and portable and central chillers. The all-galvanized cooling towers feature an induced-draft, cross-flow design that saves on fan and pump power. An energy-saving gravity-flow water distribution system and unique nozzle design for precise distribution work over the PVC film fill. The high-density polyethylene cooling towers include forced-draft (up to 100 tons) or induced draft (100 tons+) designs feature a PVC water distribution system and fill material to facilitate even water distribution and high-efficiency cooling.www.mokon.com
