Exair Corp
Np Exair Cabinetcooler 1540 5eb0ce90e11d6
Keep Electrical Enclosures Cool
May 5, 2020
Exair Corp.'s Dual 316 systems maintain air temperature at 20°F (-7°C), removing the heat and sealing electrical devices from corrosion and oxidation.
EXAIR CORP.'s new Dual 316 Stainless Steel Cabinet Cooler® systems with Electronic Temperature Control (ETC) keep electrical enclosures cool with 20°F (-7°C) air, while maintaining the NEMA 4X rating of the enclosure and removing the heat that could adversely affect the internal components. The wear, corrosion, and oxidation resistance of Type 316 stainless steel promotes long life and maintenance-free operation for foundries and other industrial operations.
Cooling capacities up to 5,600 Btu/hr. are well suited to larger enclosures and heat loads.
Exair’s digital ETC provides precise temperature control for your electrical enclosure that is constantly being monitored by a quick response thermocouple. It joins Exair’s complete line of NEMA 12, 4 and 4X Cabinet Cooler systems which are available from 275 through 5600 Btu/Hr. They are available from stock in aluminum, 303SS and 316SS materials. Exair offers hazardous location cabinet coolers with UL classified listing for classified areas in need of cooling. The broad line also includes non-hazardous purge models, high temperature models, continuous operation and thermostat-controlled models.
Dual 316 Stainless Steel Cabinet Coolers are available with cooling capacities of 3,400 up to 5,600 Btu/hr. All Cabinet Cooler systems are UL-listed and CE-compliant. Applications include cooling control panels used in foundries, chemical processing plants, food processing and pharmaceutical processing, and locations with corrosive atmospheres.
Learn more at www.exair.com
