Verti-Lift
Verti Lift Double Wide Lifts 800 5faa145b2b513
Double-Wide Scissor Lifts for Large, Bulky Material
Nov. 10, 2020
Durable, economical 72x96-in. lifts with vertical travel from 24 to 60 in., feature heavy-duty cylinders, internal power units, lifetime-lubricated bearings, safety maintenance blocks, and standard hand controls.
VERTI-LIFT introduced double-wide scissor lifts with dimensions to 72x96 inches and capacities to 6,000 pounds, to lift and position large, heavy, bulky items easily. Vertical travel from 24 to 60 inches is available to aid ergonomics and enhance productivity.
The design includes heavy-duty cylinders, internal power units, lifetime-lubricated bearings, heavy-duty tubular legs, safety maintenance blocks, and standard hand controls. Designed for a long service life, these units are durable yet economical to purchase and operate.
The developer works with distributors and system integrators to design, build, and integrate material handling equipment into new or existing facilities and production lines in many industries.
Many options are available to match the lift tables to the task at hand, including accordion skirting, oversized platforms, platforms with beveled edges, pit-mounted units, portability packages, turntable tops, detent stops, tilt table mounted to lift, conveyor, PLC control, foot pedal control, external power modules, high-cycle count packages, and more.
The lifts are U.S.-made and available from material handling distributors nationwide.
Verti-Lift manufactures a complete line of standard and custom materials handling and ergonomic equipment including hydraulic and pneumatic scissor lift tables, hydraulic and pneumatic tilters, hydraulic and pneumatic work positioners, turntables, operator lifts, 2-post vertical lifts, self- leveling carts, platform trucks, and work stations and more. Video demonstrations of Verti-Lift Hydraulic and Pneumatic Work Positioners are availale on YouTube (search “Verti Lift”.) Learn more at www.verti-lift.com
