Saint-Gobain Abrasives
Sga Blaze X F980 Nr Rev 6046f11d4f3de
Ceramic-Alumina, Micro-Fracturing Grain Grinding Discs
March 9, 2021
The new Norton BlazeX F980 fiber discs incorporate a proprietary heat-dissipating technology that increases cut rate and performance life in stainless steel and harder-to-grind materials.
SAINT-GOBAIN ABRASIVES introduced the Norton BlazeX F980 fiber discs with a premium ceramic-alumina, micro-fracturing grain for grinding in stainless steel and harder-to-grind materials. New, proprietary Cool Friction technology dissipates heat during grinding, reducing rework and extending the performance life of Norton BlazeX F980 fiber discs.
Norton BlazeX F980 fiber discs are suitable for stock removal, deburring, beveling, blending, cleaning/detailing, and finishing in metalcasting operations. Other industrial applications include MRO, metal fabrication, welding, oil-and-gas, energy, and shipbuilding.
In addition, a self-lubricating grinding aid treatment and active filler contribute to producing cool cuts. Its micro-fracturing grain consistently exposes sharper grain edges to deliver a better cut rate and longer disc life when compared to blended ceramic alumina discs.
“Due to improved ceramic grain together with our new Cool Friction technology, self-lubricating grinding aid and active filler, there is a 50% increase in cut rate and disc life when using Norton BlazeX F980 fiber discs compared with Norton Blaze F980 fiber discs and other leading discs,” said Patrick Carroll, Norton | Saint-Gobain Abrasives senior product manager. “Prioritizing the operator experience is first and foremost, so Norton BlazeX F980 fiber discs deliver a smooth cut requiring less pressure, resulting in less fatigue and longer times between change-overs.”
BlazeX F980 Fiber Discs are offered in 36 grit and are available in a standard 7/8-in. hole pattern fitting most angle grinders, and in the most popular sizes for any application.
The Speed-Change BlazeX F980 fiber disc version features the Norton quick, tool-free, twist-on/off Speed-Change fastener. Discs lock to standard back-up pads with a unique nut design and are easily removed, increasing productivity with more time to grind.
Previously available BlazeX discs include BlazeX F970 fiber and quick-change discs for carbon steel and soft-to-grind materials. Learn more at www.nortonabrasives.com
