Allegro Industries
Allegro Industries’ 18-in. diameter (PN 9541-18) high-output fan with three blades.
Powerful Air Circulation to Improve Worker Comfort
May 31, 2022
Durable, high output fans are built for high velocity performance, superior distance of air throw, and quiet operation, for indoor or outdoor use.
ALLEGRO INDUSTRIES’ new high-output fans (PN 9541-18 and PN 9541-22) are designed to withstand tough working conditions in industrial settings and warehouses; as well as offering a refreshing breeze in a variety of work settings. These durable high output fans are built for high velocity performance, superior distance of air throw, and quiet operation. The heavy-duty, high-impact LLDPE housing is a vibrant yellow color and is ideal for indoor or outdoor use.
The fan provides 360° turn radius and 130° tilt angle to push air where it's needed.
Available with optional metal swing arm or wall mount brackets, the recommended applications are manufacturing operations, distribution centers, warehouses, and many other workplaces in agriculture, food processing, pulp-and-paper, and more.
These rugged high output fans are available in two sizes: 18-in. diameter (PN 9541-18) with three blades, and 22-in. diameter (PN 9541-22) with two blades. They are constructed of high-impact, linear low-density polyethylene (LLDPE) with zinc-plated steel grills. The fan blades are made from corrosion-resistant aluminum engineered for maximum air velocity and smooth, quiet operation. The yoke bracket and motor mount are made from powder-coated steel and the Venturi style inlet helps to create an even column of non-disturbed air flow.
The product is shipped completely assembled. The ½ HP motor is UL recognized, and CSA-certified. Voltage/Hz: 115V-230V AC, 60 Hz. Max RPM is 1725 and requires 5 Amps.
Learn more at www.allegrosafety.com
