Temperature Control Units
June 25, 2007
REGLOPLAS' 300L and 300LD temperature control units have a maximum heating capacity of 80kW. Solid-state relays are part of standard equipment, with two-level monitoring for interruptionfree operation. The full line includes units for water up to ...
REGLOPLAS' 300L and 300LD temperature control units have a maximum heating capacity of 80kW. Solid-state relays are part of standard equipment, with two-level monitoring for interruptionfree operation. The full line includes units for water up to 90° C, and oil up to 150° with heating capacities 6080 kW; pressurized water units up to 160°C, high pump capacities up to 240 l/min, and heating capacities up to 60 kW; and high-temperature units for oil for up to 350°C, heating capacities 6-40 kW in single and dual-circuit versions. www.regloplas.com
