Martech Services Co.
Vertical Machining Center
Feb. 28, 2008
FADAL’S MAG Fadal VMC 6535-40T is a robust, economical vertical machining center with a work table of 7535 inches that provides broad flexibility in terms of workpiece size and multiple-part setups. The machine delivers high material removal ...
FADAL’S MAG Fadal VMC 6535-40T is a robust, economical vertical machining center with a work table of 7535 inches that provides broad flexibility in terms of workpiece size and multiple-part setups. The machine delivers high material removal rates and reduced part cycle time, while holding ±0.0002 in. axis positioning accuracy. Heavy, cast-iron construction and flame-hardened box ways support heavy workpiece machining, providing the rigidity and vibration damping required for aggressive metal cutting applications.
www.fadal.com
