IR Thermometer for Metals
RAYTEK's Marathon MM 3M infrared sensor measures low-to-medium temperatures with accuracy, regardless of changing emissivity. It was designed specifically for temperature-measurement challenges in metal processing. It uses a shorter infrared ...
June 25, 2007
RAYTEK's Marathon MM 3M infrared sensor measures low-to-medium temperatures with accuracy, regardless of changing emissivity. It was designed specifically for temperature-measurement challenges in metal processing. It uses a shorter infrared wavelengths in order to minimizes errors due to the uncertainty of emissivity. The new thermometer is not as sensitive to changes in emissivity on the target material as long wavelength sensors, and as such, provides more accurate readings across varying targets at various temperatures. www.raytek.com
