Compact HMC
June 29, 2008
3-, 4-, 5- axis configurations
HAAS' new ES-5 series HMCs are compact and affordable horizontal machining centers with generous 40x18x22-in. travels, and a VMC-style enclosure that provides good visibility and access. Each machine features a 24+1 tool side-mount tool changer, and is equipped with an 8000-rpm, 40-taper spindle that uses an inline, direct-drive system that couples the motor directly to the spindle for fine surface finishes.
