Martech Services Co.
High-Precision Roundness and Cylindricity Measurement System
March 6, 2009
For large diameter and large radial-swing components
TAYLOR-HOBSON'S Talyrond XL is a high-precision roundness and cylindricity measurement system for large diameter and large radial-swing components which can measure components with diameters up to 1000 mm. Its vertical column sits on precision-bearing rails and can be adjusted and fixed in the radial direction to suit the diameter of the component under test.
