Vessel Lifter
Lifts Up To 4,500 lbs
ANVER's BA1-RV custom vacuum lifter for vessels features three articulated rubber suction pads which adapt to different diameters from 85-110 in. and can lift up to 4,500 lbs. Designed for use with a crane or a fork lift and boom, this battery-powered vacuum lifter is suited for handling vessels in a plant or at a job site and eliminates the need to weld on lifting eyes. Features a 1/3 HP motor, front mounted controls, and ergonomic handlebar.
