Standalone IR Thermometer
June 25, 2007
IRCON's Modline 5 series of standalone infrared thermometers are designed to handle the challenging demands of manufacturing environments. Incorporating a stainless steel NEMA 4 rated housing to protect against corrosion and humidity, ...
IRCON's Modline 5 series of standalone infrared thermometers are designed to handle the challenging demands of manufacturing environments. Incorporating a stainless steel NEMA 4 rated housing to protect against corrosion and humidity, high-temperature cable, and completely sealed electrical connectors and electronics, it is designed to perform reliably against some of the harshest production environment conditions. www.ircon.com/modline5
