Paper Provides Protection Against Moisture, Corrosion
June 25, 2007
CORTEC's VpCl-144 is designed as a replacement to environmetally unfriendly products, such as papers coated with wax and polyethylene. The VpCl-144 has 100X greater barrier properties than polyethelene-coated paper, at a lower cost. It provides ...
CORTEC's VpCl-144 is designed as a replacement to environmetally unfriendly products, such as papers coated with wax and polyethylene. The VpCl-144 has 100X greater barrier properties than polyethelene-coated paper, at a lower cost. It provides multi-metal protection in various conditions, is non-toxic, nitrite free, and has no other harmful compounds. www.cortecvci.com
