MASTER CHEMICAL CORP.'s Trim C276 is designed to be stable in hard-water applications over 60 grains of hardness, and will not leave undesirable residues to a similar product, as was the Trim SC536 product. Both formulations meet the needs of demanding manufacturers, using the latest synthetic coolant formulations with a specially synthesized oil to produce versatile products that reject tramp oil, have great sump life, and are kind to machines and operators. Both will perform in centerless and cylindrical form grinding as well as on high-speed, single-point turning, and down-the-hole-work on vertical and horizontal machining centers.
www.masterchemical.com
