Split Configuration Temperature Transmitter
June 9, 2008
Accurate measurements in spaces where conventional thermometers wouldn't fit
E INSTRUMENTS' IRtec Rayomatic 12 is an infrared temperature transmitter with a split-configuration separating the main unit from the sensor head. This design allows the Rayomatic 12 to provide accurate measurements in spaces where conventional thermometers would not fit.
