Anti-Seize, Lubricating Compound
Dec. 17, 2007
Protects Against Seizing, Galling, Rust, Corrosion
GASOLIA's Thred Gard is a powerful, anti-seize and lubricating compound, available to help protect against troublesome industrial and manufacturing environments. The formula is non-dripping and non-hardening, making it ideal for use on nuts, bolts, bushings, turbines, sleeves, couplings, and other interlocking components. It speeds assembly and disassembly, helping technicians reduce maintenance downtimes.
