Martech Services Co.
Depressed Center Wheels
Dec. 19, 2006
CAMEL GRINDING WHEELS Fast Cut Series aluminum-oxide type 27 depressed center wheels have N-grade bond for right-angle grinders. The single-grain grinding wheels are engineered with a soft N-bond for high stock removal and a high wheel loss ratio. ...
CAMEL GRINDING WHEELS Fast Cut Series aluminum-oxide type 27 depressed center wheels have N-grade bond for right-angle grinders. The single-grain grinding wheels are engineered with a soft N-bond for high stock removal and a high wheel loss ratio. Available in 4-, 4.5-, 5-, 7-, and 9-in diameters and with 1/8 pipeline type 27 depressed-center wheels for right-angle grinders, type 1 cut-off wheels for die grinders, and type 1 cut-off wheels for circular saws.
www.cgwheels.com
