Martech Services Co.
High-Speed VMC for Large Mold Manufacturing
March 21, 2007
MAKINO's V99 and V99L vertical machining centers are engineered to provide accuracy and high-speed performance previously unobtainable with large die/mold milling machines. These improvements help to eliminate or reduce benchwork and ...
MAKINO's V99 and V99L vertical machining centers are engineered to provide accuracy and high-speed performance previously unobtainable with large die/mold milling machines. These improvements help to eliminate or reduce benchwork and post-production polishing on large die and mold work. Both have X-, Y-, and Z- axes of 59 × 39.4 × 31.5 inches, with rapid traverse and cutting federates of 787 IPM, and come with a #40 taper 20,000-RPM, or a #50 taper 12,000RPM spindle, as standard equipment. www.makino.com
