Electric Wire Rope Hoist
Jan. 28, 2008
KONECRANES' CXT1 electric wire rope hoist is designed to meet the demanding needs of a broad range of industrial lifting applications, ranging for one and two ton lifting applications. A replacement hoist for existing bridge cranes, jibs, and monorail ...
KONECRANES' CXT1 electric wire rope hoist is designed to meet the demanding needs of a broad range of industrial lifting applications, ranging for one and two ton lifting applications. A replacement hoist for existing bridge cranes, jibs, and monorail applications, they are designed with large diameter drums and true lift reeving for longer cable life and accurate load positioning.
