Thermal Imager
Dec. 3, 2007
For Atmospheres 392-1,652 F degrees
WAHL INSTRUMENTS' Heat Spy thermal imaging cameras work in atmospheres ranging from 392-1,652°F, especially suited for use where high temperature measurement is required, such as the metal and refractory industries. Light, compact, easy to operate, and designed for hand-held use, it also features a tripod for remote use. It is fully radiometric and measures the temperature in every pixel. The easy report software allows the user to insert multiple images with data for an inspection report, from the 160 x 120 pixel camera.
