Central Chilling
Creates shorter cycle times
Oct. 20, 2008
FRIGEL'S Microgel is a compact water-cooled integrated chiller/TCU. Its uses a Frigel-patented process that allows the set temperature to remain precise and constant. The constant temperature (2 degrees F), along with the infinite, independent temperature variation at each process machine, produces a competitive edge for metal processors. Ideal for processes where heat regulation is required between 23 and 195 degrees F.
