Precision Fluid Dispensing
Nov. 22, 2006
FLUID METERING INC. s IDS2000 dispenser consists of a patented valveless ceramic piston pump directly coupled to a precision stepper motor. The stepper motor and step-per driver electronics are packaged in a rugged, splash-proof stainless steel ...
FLUID METERING INC. s IDS2000 dispenser consists of a patented valveless ceramic piston pump directly coupled to a precision stepper motor. The stepper motor and step-per driver electronics are packaged in a rugged, splash-proof stainless steel enclosure. It will dispense up to 7 mL and is ideal for dispensing solvents, lubricants, cleaning agents, flux, and adhesives. The unit consists of a dispenser, quick-run-module, power supply, and foot switch.www.fmipump.com
