Bar-Code Scanner
Dec. 19, 2006
ACCU-SORT SYSTEMS AXIOM-X is a versatile, multiple laser, omni directional bar-code reader that provides the largest depth of field and transport coverage available in a single scanner. Its scan rate of 1,120 scans/second ensures the highest ...
ACCU-SORT SYSTEMS AXIOM-X is a versatile, multiple laser, omni directional bar-code reader that provides the largest depth of field and transport coverage available in a single scanner. Its scan rate of 1,120 scans/second ensures the highest possible read rates on both good and poor quality codes. Most applications require only a single scan head. Comes standard with serial, ether-net TCP/IP, and UDP connectivity.www.accusort.com/AxiomXHD
