Permanent Lifting Magnets
April 1, 2009
Without slings, hooks, or cables
ERIEZ'S SafeHold permanent lifting magnets can lift and transfer steel and iron without slings, hooks, or cables. Available in several models to meet specific application demands, they offer lifting capacities up to 10,000 lbs. When properly installed and operated, SafeHold magnets provide greater safety than other mechanical material handling devices. Plus, the line does not require any electricity. Available in four different series: SafeHold APL (ideal for quick and efficient handling of steel where access is limited); SafeHold EPL (designed for machine shop use to carry semi-finished products); SafeHold RPL (used for round and flat materials); and SafeHold XPL (round and flat materials ideal for machine-shop use).
