High-Capacity, Hydrostatic Batch Mixer
Nov. 28, 2011
Efficiency and reliability in 2,200-lb. capacity machine
The Pan Mixer is designed for safe and easy operation, with a control panel for mixing and material discharge operations on a large operator platform. The bottom discharge has a hydraulically activated sliding door, so material can be discharged quickly.
BLASTCRETE EQUIPMENT CO.’s 2,200-lb. capacity hydrostatic mixer is designed for refractory installations and precast refractory shapes manufacturing. Featuring the capability of 0.50-in. aggregate and mix time of 2 to 3 minutes, this pan mixer reportedly mixes up to 1-metric ton of castable refractory.
The Pan Mixer is designed for safe and easy operation. The 15-square foot operator platform includes a user-friendly control panel for mixing and material discharge operations. The bottom discharge features a hydraulically activated sliding door, allowing material to be discharged quickly from the mixer, where it is carried to a pump or transported into a mold. Material discharge height is variable up to 72 in., thanks to adjustable telescoping legs.
The developer calls the Pan Mixer “the most economical refractory mixer on the market,” and indicates it has been designed for fast cleaning and maintenance. All crucial maintenance points are easily accessible, it reports, and the mixer features hydraulic tilt capabilities for simplified cleaning. To simplify cleaning, an optional 2,000-PSI hydraulic pressure washer is available.
The machine is supplied with a standard 40-HP electric motor, with starter and disconnect. It can be customized with voltage and Hz options according to customers’ needs. Forklift pick-up points add convenience and aid in easy transportability. The machine is CE Certified and backed by Blastcrete’s customer service and support worldwide.
Visit www.blastcrete.com.
