Casting Machine
Jan. 14, 2010
Production of small, complex zinc die castings
LAMA AUTOMATION'S LamaCaster is a fast cycling four-slide machine for the highly efficient production of small and complex zinc die castings. It is a very fast and flexible machine that enables the creation of low inertia manufacturing systems. This type of manufacturing system is characterized by high levels of productivity, flexibility and competitiveness achieved through high cycle speeds, optimal raw material usage and low cost tooling that combine to deliver maximum process effectiveness.
