5-Axis VMC
July 28, 2008
Excellent automation capabilities
MAKINO'S D500 5-axis vertical machining center designed for complex part production where part quality is paramount. The work zone is 500 x 450 mm, with X-, Y-, and Z-axes providing strokes up to 550 mm, 1000 mm, and 500 mm, respectively. Rotary table axes A and C provide rotational motion from -120 to 30° on the A-axis and a full 360° on the C-axis.
