Progressing Cavity Pumps
July 26, 2007
Cost-effective solution for a general utility pump
MOYNO'S 300 Series progressing cavity pumps are a cost-effective solution for applications requiring a general utility pump, able to handle clean, clear liquids to abrasive and corrosive fluids. Ideal for water sampling, chemicals, oily water, slurries, drainage, and drum transfer. Its compact, lightweight design allows for flexible installation and is available in motorized or non-motorized versions. Self-priming, quiet, and low maintenance, it handles flow rates up to 15 GPM, pressures up to 150 PSI, and fluid temperatures up to 210°F.
