Waste Oil Heater Line
Dec. 10, 2007
Able To Serve As Secondary Heating Source
LANDA's new waste oil heaters provide an economical alternative to disposing of used oil. As energy prices climb, waste oil heaters can reduce heating bills by serving as a secondary heating source, and can eliminate the cost of hauling used oil offsite for disposal. Available in four models, it features integrated air compressors that produce clean, dry air, multi-direction air louvers to direct heat where it is needed, and a swing-out removable burner for easy cleaning and maintenance.
