Martech Services Co.
Hygroscopic Breathers
June 25, 2007
SPHINX ADSORBENTS Des-Case hygroscopic breathers replace standard breather caps to prevent dirt and water contamination, extending the service life of oils, filters, hydraulic fluids, and system components. Fully self-contained, they employ a ...
SPHINX ADSORBENTS Des-Case hygroscopic breathers replace standard breather caps to prevent dirt and water contamination, extending the service life of oils, filters, hydraulic fluids, and system components. Fully self-contained, they employ a desiccant to extract water vapor from the air- and micro-fiberglass pleated filters that remove particles down to one micron. www.sphinxadsorbents.com
